2001 Maxum 2100SR Ignition beeping
jakeamckee
when you put the key in and turn to the on position it beeps which is normal. once the boat turns on the beeping should stop, but it wont
why does it continue to beep after it is running?
Jake mckee
jakeamckee@gmail.com
tim2740
Re: 2001 Maxum 2100SR Ignition beeping
Jake mckee
not sure on your engine but on my 2004 200hp saltwater its a warning of something wrong. on mine i would check oil ejector.
