Mechengineer03
- Jul 30, 2010
- 16
I have a Stratos 201XL, 1990 Johnson GT 200 and it also has a Hydraulic Jack Plate. My tilt trim motor has gone out, I tried to jump the two wires straight to the battery just to make sure it was the motor. I noticed the motor has been whining for about the past 6 months or so of use and finally the other day it quit working.
OK my question is: can someone point me to a diagram/instruction detail that will show me how to install the tilt trim motor or what all is invloved to install this. I am trying to determne if I need to take it to the boat mechanic or if I can do it myself. I am very savy on things like this but I'm concerned if I am going to have to pull the motor off etc then I do not have the equipment to remove the motor off the boat. So if anyone can tell me if it is a simple procedure or not and as stated it does have a hydraulic jack plate but I didn't know if the jack plate would get in the way of replacing the tilt trim motor or not.
Thanks in advance for all the input and help and also any detail/instruction sheet someone might could send me or direct me to.
TODD
TODD
