I removed lower unit to replace impeller and when I reassembled it I am having trouble reinserting the bolt into the hole in the top of the vertical shift shaft rod. Its like it is misalligned and not hitting the hole . When I move the control to forward the bolt will screw in but not go into the shaft hole and then I cannot shift it into reverse. Pretty sure I aligned it properly when I reinstalled the lower unit and I don't remember what position the shift control was in when I removed it. I think reverse?
Is there a proper procedure for aligning the shaft hole with the bolt to be able to hit the hole and screw it in? put the shift control in forward? reverse? neutral. The prop shaft does not turn in the current situation with the bolt unattached. ? Is there a way to see the top of the shift lever by taking off the plate at the top of the engine just under the carbs and bottom case near the top of the shift rod?
I am thinking of getting someone to slowly change the shift control position a little at a time while I push the bolt in at these intervals. Whatdoyathink?
