I have read many posts here for charging problems and testing rectifiers and beaucause mechanics here [Greece] are for the bottom of a lake here is my problem.With an ommeter and the black lead on ground no readings reverse the leads and i have readings [480om] on two yellow wires but not the red wire.Now with black lead on red wire no readings reverse no readings olso.With motor on idle and multimeter on DCV i have 11.5volts on red wire.Is my rectifier dead for sure?
thanks in advance and a big hey to all of you here
