Durbinator
- Apr 15, 2011
- 2
I recently purchased an '87 fish & ski with a 260/V8 mercruiser and the trim up did not work. Using info acquired by searching the forums I determined that the Trim Limit Switch and Trim Position Sender were flaky so I am in the process of replacing them. I had previously replaced the Trim switch in the remote control handle and noticed that the wiring connector in the handle of the side mount Quicksilver 88150A7 Remote was not pinned out color to color (4wires). My remote is identical to attached pic. The previous owner had issues with the trim up and had someone at his marina work on the issue but they gave up after replacing one of the soleniods. Does anyone have Quicksilver wiring diagram for this remote that I could use to verify the wiring within the remote control unit or know where I can find one? Any help on this would be greatly appreciated. Thank you.
