chefnatewilson
- May 28, 2011
- 8
So here we go I have a 1992 evinrude 25hp TE25ELENS on a bass tracker pro 17 . We were putting along at a very low speed almost crawling . The motor just cut off no violent noise or bog it just plain stopped . We tried to restart with no luck I decided first to change to some new plugs . This did not work with all the crancking in the world and a shot of staring fluid still nothing . I noticed that the linkage attached to the carb to open the butterfly was broke off at the end . So then I tried to hold the butterfly open a bit and start it . still nothing just a couple of backfires about one every 10 rotations or so . We used the trusty MINNKOTA to get us back to the dock when I got back home I took the flywheel off to inspect the ignition system I noticed a little square tab of metal stuck to the inside of the fly wheel it look like the came of the outside of the power pack but Im not sure if it had a pickup tab on it or not . There is some scratching along the inside of my fly wheel but not very deep . Im thinking some how maybe that little linkage bar got caught up in the fly wheel and broke the tab (if there is one in there ) . What do you guys think ? could my power pack be damaged ? is there a little metal tab that goes on the back of the power pack like ?) Not sure fellas please help me out I have a tournament next weekend Thanx NAte Wilson
