Also my motor is smoking alot. i mix the oil at 50 to 1 can it be ajusted at the carb or do i ajust by changing to a 40 to 1 mixture.
40:1 is richer than 50:1. And, NO don't change it.
Thanks for the info i will try the apoxy. I knew 40 to 1 is more oil just had a brain frez.
How do I get the motor to stop smoking, or at least cut it down some. smokes more when idling or just in gear.
Thanks again
