Re: help 1980 johnson outboard
Same thing when I first got my 25hp Johnson. Choke had to be partially out.
The jets were partially clogged. I added a pretty good dose of SeaFoam. Every time out the choke needed to be open less and less. Now, no choke after start, let it warm up a minute, and go!
SeaFoam Is Not a fix all. Carbs may need to be disassembled and cleaned for it to run right. Just saying it work well in this case. Can't hurt to try.
