Hello boaters,
I am in the process of inspecting the crankshaft journals for consideration of rebuilding my engine and am curious if someone has the tolerance for the rod journals? I understand a proper manual will be needed for such an endeavor but if the crank is toast I might move on to other options. I found enough slop in the bearings to warrant this investigation.
Thanks
Thanks
