Finished restoring my 67 Stamas runabout. The 1975 rude 50hp was not my first choice but I got a sweet deal on it and the compression was good and even accross both cylinders. I took it for it's inagural (and only run) late last fall. Got on plane well. I did not see a pee stream and can't locate one. Should this motor have one? And if not how can I tell if it's pumping water sufficiently? Lastly, I decarbed and fogged according to the instructions on this site (thanks for that). But I am not sure it's running on both cylinders when I run it in a barrel. Is there a way I can tell if both cylinders are firing properly while running it in a barrel? Any feedback would be greatly appreciated.
Thanks,
Joe
Thanks,
Joe
