FYI I have very little expierence with carbs.
Equipment: OMC 4.3ltr Engine with Rochester 2 barrel
Engine stumbles around 2800 rpms and up. Starts first time, idles, and accelerated perfect untill about 2800 rpms
I noticed that the butterfly flap on my carb was always straight up and down (can see down throat of carb). I observed this when the engine is cold and when its warm.
Whats the right way? I bought a Carb rebuild kit and rebuilt the carb today. I noticed when I pulled off the choke housing assembly, the little port was packed full of carbon no air was getting through. Was this my problem? Also I adjusted the choke spring until it closed the butterfly flap. Was this the right thing to do? ANy help would be appreciated. Thanks
