I have an 86 110hp elmolcdc vro rude. I put a non vro pump on it 5 years ago and mixed my gas. It ran great until this season. The pump was leaking fuel into the engine block where the vacuum line is. I had a mechanic confirm that I needed a new fuel pump. Went to the same place that I bought the pump 5 years ago and the price went from $130 to $400. I didn't buy it. Rigged up a mikuni diaphragm fuel pump that pumps 65 liters per hour. Took it out for sea trials and ran like a bear for about 20 minutes @ wot. Then I slowed down and rode at 10mph and after about 5 minutes of that I floored it. Got up to wot for about a minute and then slowed rapidly and picked back up on it's own. It did this repeatedly. I got home and pumped out my fuel tank. There was only about 4 gals of clean gas in it. My sender is inaccurate. I replaced my water separator again and checked the factory membrane filter in the engine compartment. It was spotless. I figured that I didn't have enough fuel in the tank. So I put in 12 gals. of fresh fuel and took her out again. It did the same thing.I don't think this pump is keeping up. My boat tops out @ 35mph. If I run it @32 mph it doesn't miss a beat. I hear there are fuel pumps that can bolt onto my block that are made for evinrudes of this size.. I'd like to get a pump that will work for less than $400. I really don't have time to experiment again.Any one know what pump will fit and provide the fuel necessary.
