quick help FUEL ISSUE
xBASSASSINx
Im trying to completely rule out a fuel problem today on my Mariner 40 Magnum.I have checked the enrichment valve,redone Carbs and fuel pump, checked lines all I have left is check the bulb and valve.Im getting gas to the carbs but my question is even tho im getting gas to the carbs could somewhere in between me trying to crank the engine could the anti siphon valve some how be failing.
As of now the engine starts and spits and sputters as it will want to turn over and run but its like its not getting the gas to do it.Im almost sure its a fuel problem but still could be electrical because I squirted gas in the carbs and still nothing.Any Help is Appreciated!
