detrlions10
- May 18, 2011
- 24
Well, I have tried several attempts to get this boat running correctly, but I have failed up to this point. Basically, after running good for about 30 minutes, the motor feels like it is starting to miss. It will not pick up speed and is very sluggish. If I shut the boat off for awhile, I can restart it and it will run good for about another 20-30 minutes.
I originally thought it was fuel related, so here is what I have done so far -
Emptied the fuel tank, filled with premium.
Added Sea Foam to the gas
Replaced the fuel pump filter
Replaced the carb filter (and fuel line)
Added a fuel/water separator
What else could be wrong? I need some help here. The boat is a 1988 Sea Ray Seville. The motor is a 3.0 Mercruiser 1988
