brass water drain plugs....??
rs0607
i just bought a 77 glastron bowrider with a mercruiser 888 i/o (302 v8), it was winterized last year by marina and they left 5 little brass water drain plugs in a bag..i have no idea where they go....is there a diagram or some information on the location of these?
Fordiesel69
Re: brass water drain plugs....??
Block, exhaust manifolds, and riser elbows. Figure out where the holes are, they should be easy to find.
dubs283
two in block, one in each exhaust manifold, and should be one in each riser, if not in the risers, then oil cooler
rs0607
thats great! ill have a look tomorrow...i dont know too much about these marine v8s...i got the boat for 500 bucks and its been well taken care of ....i hope i find all the right holes...i dont even know where the oil cooler is...or the risers...:(
Utahboatnut
know where they go and gather a bit more info then you can winterize yourself and save some $$ next season..
fossill
They should not have been left out. At least according to the manual.
