I have some idea what the problem is but would like a conformation or two before getting into the tear down and repair part.
I was out the other day and headed back in after a day of fishing and the boat started to surge a little a couple of times then started losing forward momentum, after losing about half my speed i opened the hatch and found water coming in at the trans bottom, i killed the engine and pumped out the little water that was there and the water entering had stopped, getting the boat home i checked the trans fill plug and the contents are a milk color.
Now what i would like to know is there a specific seal that i will need to replace or should i replace all the seals from the out drive up to the back of the trans or just a particular seal ?
