Re: Gearcase Seal Kit for a 1956 15hp Johnson
The Seals where MFG by CR = Chicago Rawhide, which was bought out by SKF in the 90's.
As long as you have the seal number, this link will find the newest replacement now by SKF.
Here is a neat little online conversion to SKF part numbers:
http://www2.chicago-rawhide.com/popu...kup_457012.htm
Type in your seal number 302495
This is the results:
302495 JOHNSONMOTORS SKF Part # 6280
The part number is a link to the Datasheet of that item.
http://www.skfextranet.com/Catalogs/...ail.asp?s=6280
The other seal I'm looking for which Marine nor Iboats has is 41A62. That converts to SKF # 4985.
Now to try and find this seal in stock somewhere.
