I have a 2007 volvo 3.0 GLP-E with an SX/A drive. Serial #3869357 4012200520 (engine)
The hose going into the circ pump from the thermo housing popped off the other night, we noticed it quickly before the motor got too hot and put it back on and tightened the hose clamp. We noticed that the raw water outlet was a bit leaky as well, tightened that. In the morning we were cruising around at about 4kts for awhile fishing, noticed above average temp. Trolling home (8-9kts) the temp was a bit higher. Close to the harbor we ran the boat up on plane, and the temp started climbing so we shut her down and came in on the kicker. I checked the impeller, all good. Replaced a very rusted thermostat and ran the motor on the freshwater hookup all the way up to 2500rpms for 10 minutes or so, and the temp was great. Tried to fish again this morning, high temps under load at trolling speed (2600rpms). At washdown the temp was all good once again hooked up to the hose. Where should I start? Thanks for any help....
