While under power, my motor suddenly loses power, as if the kill switch lanyard was pulled from the switch. I wasn't using the lanyard..didn't have it hooked up. But after a while, the motor started again. Did this several times while running, maybe 10 minutes apart, then restarted. I jiggled the switch wires under my console, and felt the connections to the back of the ignition switch every time, and I'm not sure if I have a wiring issue or powerhead issue. Does anyone know if a computer diagnostic check would give any light to the problem? I am the original owner of the motor, and I can't recall ever using the kill switch, but the engine starts good, every time. It's underway where we have issues. Not idling, but running. After reading some other posts, it looks like there have been past issues with wiring..I am no good with electrical components, but willing to use common sense in checking out issues. Thx.
