2002 Four Winns 4.3 V6 18 ft horizon. Usually 4 people plus cooler, and 50 lbs of gear. PO had the aluminum prop replaced with an SS one straight from the dealer so i dont think he ever drove it with the factor origional prop, this one is a 14.25 x 21 pitch, dont know the manufacturer. It will turn 3800 WOT, and 32-35 mph max. I think the prop is too much, considering going to a 19. I water ski and pull a tube regularly, I believe this boat has more potential on the max mph. Engine checks out good 145-155 compression on all cylinders, recent carb work, spark plugs etc...Thanks guys
