  #1
Old February 23rd, 2004, 11:36 AM
edandq edandq is offline
Default Floor for 16' Aluminum boat
I'm in the process of restoring a 1970 16' Aluminum Starcraft. The hull is in fantastic shape with no leaks, but the floor was shot. I removed it and amd getting ready to replace it. I've bought marine grade plywood, and will cover it with marine grade vinyl when installed. My question is this. How do I treat the wood before I lay the flooring over it, or should I? I want to keep the cost down, but just dont' know what product(s) to use.
  #2
Old February 23rd, 2004, 01:58 PM
Solittle Solittle is offline
Default Re: Floor for 16' Aluminum boat
Saturate with epoxy resin.
  #3
Old February 23rd, 2004, 02:06 PM
Lark40 Lark40 is offline
Curious about "marine grade" plywood.What kind of a place did you buy it from? Have read past posts saying that it doesn't really exist.I have always bought exterior grade construction plywood, and then saturated it with epoxy resin, as SoLittle suggested.
  #4
Old February 23rd, 2004, 03:46 PM
Well, I got the marine grade plywood at a local lumber store for boats (live out near Seattle)...I've read the posts supporting both for and against, and the price difference wasn't that much so I went with the marine ply. As for saturating with expoxy resin, I've never used it. Do I need to mix it? Is there a particular brand? An easy way to do it? Any tips will be wonderfull appreciated. Thanks so far for the responses!
  #5
Old February 24th, 2004, 02:21 AM
cobra 3.0 cobra 3.0 is offline
Is it made with BC fir or spruce? The fir is much better in the long haul under wet conditions.I suppose to be marine grade, it must be fir.I would treat the cut edges before installing it.
  #6
Old February 24th, 2004, 05:04 AM
It's made with Doug Fir... you say to treat the edges and treat before cut, are in concurrance with others and say treat with epoxy?
  #7
Old February 24th, 2004, 08:05 AM
Wood preservative used in making pressure treated wood (green stuff) would be my choice. It penetrates into the wood and cannot crack or wear off. I'd stain it over top, bottom, and the cuts. It will keep it from rotting.Here are some sites on marine plywood that may be of interest. http://www.westsystem.com/webpages/e...8/plywood.html http://www.glen-l.com/wood-plywood/marine-plywood.html
  #8
Old February 26th, 2004, 04:14 AM
missed_shot missed_shot is offline
go to a welding shop and have them weld an aluminum sheet the thickness of a road sign instead of wood. I had this done and no more problems. cover with carpeting .
  #9
Old February 26th, 2004, 04:34 AM
Fly Rod's Avatar
Fly Rod Fly Rod is offline
The Lund boat that I had,had pressure treated plywood and then like a vynil flooring. Held up for 6 years and the fella up street still has the same floor
  #10
Old February 26th, 2004, 04:58 AM
ED21 ED21 is offline
Master Chief Petty Officer
missed_shotJust curious- Does the boat seem any louder without the dampening effect of plywood.How is the aluminum to stand on & does it flex more than the plywood. I realize you put carpet on it.And finally what was the aprox. cost.Of all the posts I've read about replacing floors I've never heard about using alum. It sounds interesting.
  #11
Old February 26th, 2004, 01:40 PM
Appreciate all the responses. The floor I removed was 35 years old, and it wasn't coated in epoxy. That being said, I think I'll just treat the wood, use the good glue for the vinyl, and be done with it. If it lasts 10 years, I'll be happy, doubt I'll have the boat that long. I probably could have went with a fancy composite or aluminum, but didn't think of it at the time. Now I just have to figure out how to attach the wood. I will probably just screw, I hear the add weight, but it can't be that much...
  #12
Old February 27th, 2004, 02:24 AM
Ed - I don't think it sounds any louder than wood. I put the blue building insulation under the aluminum between the ribs. It deadens the sound and adds a little to the flotation incase I forget to put the drain plug in .The ribs on my boat were fairly close so I have a solid floor.
  #13
Old February 27th, 2004, 08:31 AM
missed-shotThanks for the reply. I'll put that into the mix for deciding how to approach my spring project. The weather is going to be in the 50's this weekend. It won't be long now.
  #14
Old June 5th, 2009, 08:14 AM
brightwl brightwl is offline
I advise against using the wood treatment used in pressure treated plywood.
It is very corrosive when put against aluminum. If you are using vinyl over
the floor the vinyl will give some good protection. I would use a latex base paint and put a couple coats especially on the edges. That will give you a good seal and not effect the bond when you put your vinyl floor down.
  #15
Old June 5th, 2009, 09:12 AM
ezmobee's Avatar
ezmobee ezmobee is offline
Send a message via MSN to ezmobee
5 year old thread.............
__________________
1976 18' Starcraft SuperSport 90HP Evinrude
Restoration thread http://forums.iboats.com/showthread.php?t=357767
1966 16' Starcraft Jupiter 85HP Johnson
Restoration thread http://forums.iboats.com/showthread.php?t=338633 sold
Closed Thread
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Floor in Aluminum Boat jd438 Boat Restoration and Building 2 April 20th, 2006 04:54 AM
Aluminum Boat Floor Replacement turtle1173 Boat Restoration and Building 16 November 20th, 2005 07:55 AM
Installing floor in aluminum boat MartinR Boat Restoration and Building 8 September 13th, 2003 07:36 PM
aluminum floor dustinatdana Boat Topics and Questions (not engine topics) 1 September 13th, 2003 07:05 AM
aluminum boat floor.... longshot Boat Topics and Questions (not engine topics) 1 October 1st, 2002 07:31 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
