speedzone and express props?
bobhamclint
I have been looking into stainless steel props, but don't want to spend too much. I want to get a low pitched prop for wakeboarding, and I also want another, higher pitched, prop for cruising and top-end speed. Would Express make a good choice for an affordable prop for wakeboarding? and Speedzone for cruising? or are there any other prop companies anybody could suggest? The boat I'm using is a 2001 Searay 18' bowrider. It has a 4.3 liter I/O in it.
D
DJ
Guest
Re: speedzone and express props?
Don't know hat kind of set up you have. But, you might want to look at a variable pitch prop. The "Land N Sea" Aerostar is a good two pitch prop that switches itself depending upon load.<br /><br />It has been very succesful on low hp. I/O's like the 3.0 L.
