I have a 1981 cruiser with a 165 mercruiser engine, and alpha one stern drive. Yesterday while using the boat in 5ft swells the boat started not wanting to take any throttle. We hit a swell pretty hard and as soon as we came off of it, the boat would no longer take more than 1/4 throttle. It idles fine, and drives fine, but I can't give it any throttle if I try it bogs down. The more I try the worse it is. The fuel is clean and fresh,and the filter is clean. Mine is a glass see through type. Thought the float might have stuck. So I took off the top of the carb to free it up, but it was fine. Fuel pump looks dry(not weeping). If I shut it off it will restart with no problem and run fine just can't accelerate. Anyone have any ideas?Possible fuel pump?
