I have a 04 Mercruiser 5.0 carb that used to have a sterndrive with serial number OW505786 which I believe had 1.62 or 1.65. The guy before must have hit a rock or something and replaced the drive with serial number OM441966 which has a gear ratio of 2.0. I currently can run a 23 - 25 pitch prop, If it makes sense $$ wise, can I change the gear ratio back by changing the gears, or should I be looking to swap out the drives and at what cost are the gears?
