Re: Newbie needs advice, please help
Changed and/or cleaned doesn't necessarily equate to maintenance. Unless you are loading it extremely heavy, if it's not planing you've got something "broke". You really need to start at the very beginning, which is do a compression test, then a spark test then a fuel test. If you want help, you should post exactly what type of engine and jetdrive you have, as the name of the boat won't help. That jet boat should easily plane and reach 45mph with 2 people on it. Planing itself shouldn't take over 2 seconds, I'd imagine. I wouldn't run that boat until you've done those 3 things mentioned, or had someone do them for you.
Starting it with "ether" is your first clue. There's something definitely wrong on the "fuel side", but start with compression first, then spark, then fuel.
