Is the engine injected or carb'd?
oh I did replace a belt last year. Could this possible impact the engine??
.Yeah I know that I should do that. wow at least 3 years ago. I guess my rational is that I only use the boat 6 times a year. 2 years ago I took the boat in for a $32.00 water pump rebuild and walked out spending 1600 not sure on what....... I'm very nervous about our local volvo penta dealers in San Ramon - Antioch CA
That drive needs to come off every year, alignment checked, and the splines greased on the coupler shaft. At that time the gimbal bearing and ujoints are greased and inspected, and check for water in the bellow.I had the entire lower end serviced in 2008, ujoint etc.
