Re: oil control module
Mariners, that magnetic switch on the top of the oil pump counts the number of revolutions the oil pump drive shaft makes, and compares it to an ignition signal [usually #4 cyl].....one revolution, one spark pulse to a coil.....if a difference between the 2 shows up, the oil control box gives a beep-beep sound [overheats give a continuous tone]....so, what is broken? #1 if the oil gear on crankshaft is failing, the pump shaft will 'skip'and you will get an intermittent alarm. this will get progressively worse. #2 if the ignition signal is failing, it will alarm the same way...it could be a bad switch box...seeing as you checked output of pump and alarm stopped with sensor unhooked, I would look at the ignition...that motor been down a little on power?
