Need alittle help my timing is backward when i start the motor. It is advance at a idle and then retards when i advance control arm. I did pull the flywheel to see if the center ring was loose on it and it look ok. I have a evinrude that has done this and it was the center ring on the flywheel. Any other suggestions??
