Frank Acampora
- Jan 19, 2007
- 12,004
Tater: I'm answering this on the forum because some others may have valuable input.
To summarize: You converted a Chrysler 55 HP engine with points ignition to Force 50 HP electronic ignition. You are now having trouble setting timing to 30 degrees.
You are in uncharted territory since I don't think anyone would have taken the time to do this.
I also have a 55 sitting outside my garage in process but I can not help you because it is not finished.
However, I can say that you must recheck your settings. While TDC and 32 degrees advance is a given and set on the flywheel, that does not necessarily mean that it is the same for electronic. The linkage MAY advance the trigger a different amount for electronic than it does for points. AND, the flywheel center magnet MAY be related to the trigger differently than the cam and points.
To answer your other question: You engine still needs to be at 30-32 degrees maximum timing advance at WOT. I know by experience that 40 degrees advance is too much.
