HELP!!! I am leaking oil from a 2003 60hp Bigfoot while boat is sitting. I have replaced the holding tank, new tubing to the oil pump and removed the oil pump to find a couple "C" rings instead of "O" rings and thought that was the problem but it is still leaking defiantly from around the pump. Could it be a bad oil pump or did I replace it with the wrong o-rings? I am completely stumped...please help before I get over-ran with gray hair!!! Thanks in advance?.
