1979 1150 Mercury Outboard
drvn4sxs
Can someone tell me if I have white pasty stuff on my spark plugs, does this mean Headgasket required????
cr2k
Re: 1979 1150 Mercury Outboard
Cant tell you if you have anything on your spark plugs without seeing them.
Chris1956
That motor does not have a removeable head. Water can get in thru the exhaust ports, however.
Faztbullet
If its lower cylinders, it is fuel & water mixed likely from bad lower crankshaft seals...
