First off, i would like to say, thanks to those who helped me on my other issues. We took her out yesterday and today for the first time in over 3 years. Now im having an issue. The first time the boat starts up it seems to start up OK, i still have to start it a few times for it to keep idling. After its been ran and shut down is when it REALLY starts to act up. It takes me a couple of minutes to get it running and when i put it in gear it will shut down and start to bog a little, after a few times i get it up and going. I brought it home and richened up the idle screws 1/4 turn and it fired right up in my yard. Anything else to look for? Im under the assumption that the fuel needles were a little lean and it caused that problem. Ill get to work on whatever you guys suggest. Ill give you guys a run down of what i did before the boat went in the water:
Replace cdi box
replaced ignition trigger
set timing to 28 degrees at WOT
synced the carbs
cleaned the carbs
replaced all fuel lines
made sure the reed valves werent stuck open
new primer bulb
Replace cdi box
synced the carbs
cleaned the carbs
new primer bulb
