retiredfornow
- May 9, 2011
- 355
It's an E60TLCCR and I can't find the fuse holder as shown as #39 on the following link:
http://www.ishopmarine.com/ishop/js...CatFilter=BRP&eCatSupFldr=supplier-100-005-EJ
At the main harness plug, that exits the motor, has wiring that doesn't match my factory service manual. There are 2 wires that are cut, one brown and one grey. Is this where the fuse holder used to be? This motor (my first) has been a struggle, due to my ignorance and the abuse by the former owner. Thru the help here, she's almost done! Thanks.
The wires at the plug are: Purple/blue, 2 greys (one cut), 2 browns (one cut), 2 blacks, yellow/red stripe, yellow, 2 reds. Some of these wires must be spliced together inside the plug, since it's an 8 pin plug. Any help or suggestions would be appreciated. Thanks.
