aguynamedmike
- Mar 27, 2011
- 17
I got a 1977 Bayliner Mosquito title says 15' but it measures 14'7"
Got it from a from an aquantances brother and never bothered to stand in it, I only did a compression check and watched it pee looking at some reciepts for new wheels n tires on the trailer, handed him the cash and drove away.
Took it out a couple times and felt a cpl small soft spots here and there. Figured it was good till the end of the season then I could start on it.
The back2back seats were from a bigger boat and the standing room was nil on the boat. I took the seats out and built some single jump seats with storage ect that made alot more room, unfortunately its also revealed alot more rot!!
So now I have a trip im leaving for on June 2nd about 10-11 days away.
I have pulled this boat in the garage took the plunge pulling up some carpet and drilling some 5" holes to take a peek. That turned into cutting and bashing out a 2 and a 1/2 ft sqare hole to get a better look.
Heres the thing...I have no Idea what Im doing!
Lol, I took some measurements and have came to the conclusion that I can essentialy covered the bad areas with 1 sheet of wood, and plan on useing the sheet of plywood as a template for how much floor im removing. I am a believer in doing things right but if I can make this a 3-4 yr fix thats fine with me.
All the foam is the pour in kind and some of it still feels like foam and not sponge.
So what I want to know is...
Can I cut away the most prominent rot then antifreez/borax it then sister in and glass new wood on the stringers, and pour in foam only where foam needs it most and still have a decent floor.
These are only my thoughts on how I think I may go about it. Please give me all the feed back you guys have.
Also, I am going to do away with all the carpet and rynho line the whole inside when done. Anyone got advice on common waterproof glue ply I can buy at the hardware store instead of spending 100 on a sheet?
And whats the scoop on this pour in foam how much does it cost and how does it work? expanding??
If you manage to read all of this thank you very much.
