newboatman
- May 21, 2011
- 3
I recently purchases a Reagle Rush jet boat with a 90hp Mercury Sport Jet, before I bought it the previous owner started it up on 3 separate occasions. I bought it on a Friday, took it home and didn't touch it till I put it in the water on the following Wednesday. Long story short, I drained the battery two hours later trying to get it started. It would just crank and crank all day but never fire or even sound like it wanted to fire. I should mention that not once did I ever smell any gas due to flooding. When I took it home I tested the electrical and it has great spark on all three plugs and all the coils are good. It has a stage 2 fuel pump but dose not have a bulb primer, I read in a repair manual that there should be so I went and put one in. I can get the pump to get the gas to the carbs but again I can hold the throttle wide open and it will not fire and you cannot smell any gas. I started to think that maybe he was spraying starting fluid in the intake to get it running to sell it so I bought some fluid and got it started for a second but as soon as you give it gas it would cut out. I know it runs I just cant figure out if the fuel pump is bad or the carb needles are stuck or its something I'm just looking past. If anyone has any suggestions for this I would be more than open to hear it, I'm pulling my hair out cause I know it starts.
