Re: Water sloshing in the toons.
Ya, putting drian plugs in the tubes is a band-aid fix, you need to find the leaks and have them fixxed.
There should be bungs on top of the tubes but they really aren't big enough to get water out unless you use a really small hose, the correct way to fix this is to take it a welder and have the tubes air checked and the leaks fixxed.
You should have him raise the front of the boat and drill a small hole in the back of each section until they drain then air check the boat, repair the leaks and fill the drain holes and you are good to go, they will drain faster if you remove the plugs on top of the tubes.
Your boat should have 3 sections for each tube, the nose cone, front and rear with a baffle in between each section, normally leaks are on the rear of the back brackets or on the front of the front brackets since this is a major stress point, you may even be able to see a crack if you look close but they could be anywhere so air checking is your only way to know.
The holes can easily be on top of the tubes as water splashes everywhere under the boat and can get on top of the tubes.
I am the repair guy at Bennington so I have fixxed alot of boats over the years.
