maskinmester
- May 21, 2011
- 3
Hi.
Having problem with my mercury 60hp EFI 2006.
20 amp fuse blows when first second use of tilt swicth.
Replacing fuse and tilt run for a few day, and then blown fuse again.
But in a 25 amp fuse for emergency.. Pulled the motor out of the water to locate problem.
Connected amp probe to tilt motor wire and motor draw high amps.
Motor draw 24-25 amps when tilting motor up and down.
Sometimes even higher amps during first second start of tilt motor.
Disconnected engine from tilt motor to run tilt motor without load.
Amps up 20 amps down 24
Any ideas?
Sorry for my english.
Any ideas?
