Gas Giant
- Aug 8, 2010
- 239
Now that my engine runs again, I'm getting ready to hook up an overheat buzzer I got from work to my late 80's Force 50. In order to make sure the system is working correctly, I want to make sure the temp sending unit (apparently called a "thermoswitch" by some parts websites) is actually working before I do any wiring.
I am assuming that at a certain temperature, the thermoswitch closes and creates a path to ground for the overheat buzzer, using the engine block as a ground point. If my assumption is wrong, let me know!
But assuming that is how it works, could I heat the switch up somehow (using a heat gun, or perhaps in a pot of boiling water?) and then check for continuity between the body of the switch and the wire?
I didn't see anything in my manual (not that I expect to) but if anyone has any advice or a better test method, let me know! Thanks!
