akslednecks
- May 19, 2011
- 7
Motor starts fine but it revs up and down constantly no matter what the throttle position is. When im on the water i can get it to run fine for a few minutes at open speeds. Then all of a sudden it falls on its face and starts reving up and down. New plugs and gas with seafoam. Cleaned carbs still acting the same. Then every once in a while in the driveway it will idle fine, but when i give it throttle it starts reving up and down. Its a constant up and down and will run for ever. Motor starts easily. 125psi compression in both cyl. I dont know what to do. It almost sounds electrical. Any help would greatly be appreciated. Thank You
