jbing81
- May 22, 2010
- 421
SN 125183C with OMC TnT
While removing the motor from the boat last month one of the lockbolt pins sheered, however that really isnt the issue as I can get it replaced. Im wondering if these lockbolts are the only 2 pins holding the motor to the boat?? When I removed the motor I noticed 2 threaded holes on the swivel bracket that were not being used. (no through holes in the transom) Im wondering if this was over looked when this motor was installed? Or if these lockbolts really do hold the entire motor? When I re mount the motor should I drill the additional holes for the swivel bracket or just leave it as I found it and reinstall?
Thanks in advance!
Jeff
Thanks in advance!
Jeff
