flatcatman
- May 17, 2011
- 16
I just got a 1991 Bayliner Capri 2050 bowrider. While cleaning/checking the boat over, I cannot get the motor to turn over. I pulled the plugs and poured in some Lucas upper cylinder lube to let that soak. The Crankshaft pulley is too close to the front motor mount to be able to get a ratchet on it to turn it. Anyone have any good ideas on how to get the pulley to turn. I'm sure it just needs to soak for a bit then be "powered" loose, but I just can't get anything on it to turn it. I can pry on it against the motor mount, but theres just not enough leverage. Any thoughts?
