1998 Johnson Outboard-Trouble getting power to starter
Dmyers09
I have a 98 Johnson 90 hp outboard (J90TSLECM) and cant get any power to the starter. The starter works when i jump it with cables and the boat will start, so i replaced the solenoid (SW622) but it still gets no power. The battery is a brand new Marine optima with a full charge. I know that before there were two batteries linked in a series (do i need both to run the starter?) all cables and wires look tight and in good condition. Could it be an ignition switch or something like that?
Thanks Guys
oldcatamount
Re: 1998 Johnson Outboard-Trouble getting power to starter
One (good quality) marine battery like you have, should be enough. You might get the battery load tested but it sounds more like an ignition switch problem to me.
stylesabu
Master Chief Petty Officer
do you know how to jump starter soliniod? if this works which it should. start at ign switch,if thats good there is also a nuetral safty switch in control box so you can't start it gear.
Dmyers09
Not too sure, do I jump the post that comes from the battery?
bob johnson
is your shfter in nuetral??
is the kill laynard clip in place??
you need to keep checking on the ignition circuit for a short . also check the large fuse on the engine
you may have a broken wire someplace
my connection under the floor shorted out and the black/yellow wire burnt( kill circuit) ( I have an adapter in between a new control and an old motor thus the connection is under the floor instead of under the motor cover!!)
good luck
bob
Dmyers09
Yeah shifter in nuetral and kill laynard clip is in place, I also checked the big fuse on the motor and it looked fine. Ill check the ignition circuit and the wiring. Thanks for all the help guys.
dew2
The large posts on the solenoid, one has the cable from the battery and the other side goes to the starter.Take a heavey wire and touch it to each of these posts,That is bypassing the solenoid, if the starter kicks in it may be a bad solenoid or bad connections.Personally I would start by cleaning EVERY elec. connection both battery + and- then both sides of solenoid and the starter also the small connections on the solenoid.Make sure the grounds are clean and good connections. then try the key if it dont work then bypass the solenoid.If the solenoid bypass works and the key dont
then I'd go to the keyed switch.
