justcatchin
- Aug 9, 2010
- 20
I am in the process of restoring a 19.5 ft AstroGlass F&S. As with most of these projects there were more problems than I thought. I got the stringers out and found the stiffning boards along the hull were mostly bad, so out they came. I put them back in like they were and then glassed. 1 layer of each in order, 1.5 oz CSM, 10 oz. woven cloth, 18 oz woven roving. The stringers and transom are getting the same. The transom is 2 layers of 3/4 inch AraucoPly with 18 oz. woven roving sandwiched in between. The question is does this seem adaquate, to little or over kill. I am pretty sure this is more than what was there, the stringers were not even fully wrapped!Thanks in advance for the relpys.
