I have a 72 4hp seahorse that I'm having some problems with. I'm fairly new to outboards. First, I adjusted it and got it running and after about 3 minutes it died. When I get it adjusted, I can adjust it to run well. I got it running smooth and ran it for about 10 minutes then stopped it. After that I could not restart it. I do not know if this is the carb, fuel pump, water pump, or oil. It was smoking some but it sounded like it was running well. Also, I need to get some new adjusting knobs and a pull rope. Any suggestions? Should I be using a 50:1 fuel/oil mix or what?
