markandclark
- May 15, 2011
- 20
I recently picked up this 1991 Starcraft SF 16 DLX and a matching EZ-loader 1500lbs trailer. It didn't come with a motor so as of right now I am looking for a oil injected motor that is under 40hp so any suggestions would be great. The hull is in good condition except for a spot where the previous owner had rolled it over a log while fishing. It leaks in that same spot so I am going to straighten the hull and tighten the rivets. If it still leaks then I will replace them but I have no idea on what rivets to use or where to get them. The rivets that are there now are solid aluminium and can?t seem to find any info on them searching the internet. The floors were all rotted so I ripped them out and am now trying to find the correct plywood to replace them with. I was thinking of pressure treated but I have heard that is reacts with aluminium. The floors were a half inch thick but I not sure if that is thick enough. The transom is questionable so I don?t know if I should replace it or not? I have never replaced a transom before so again what plywood would I use and is there any other things I should know about the transom? After I took out the floors I found a birds nest of wire that was not correctly wired and seemed old and dangerous so I decided to rewire the whole boat. There will be two batteries on board. One for the trolling motor and accessories and a cranking battery. I was wondering what gauge wire I should buy for the battery to the console and what wire for the accessories like fish finder, navigation lights, etc? I have many more questions but this is enough for now. Wish me luck.
