After pulling the motor on my Roughneck I found some issues and would like some advice as to how I can handle it. Here is the first thing I found when I removed the motor mount bolts...
...when I saw this I had some major concerns about the integrity of the transom. Then I probed the bolt holes and a small hole on the inside of the transom. I found that the bolt holes have about 1/2" to 3/4" inch of punky wood around them on the inside and the whole has about 1/4" of punky wood.
The inside top of the transom has a break in the gel-Coat where the washer for the bolt that holds the tilt and trim.
The rear of the transom appears solid and sounds solid except for a small change in sound between the mounting bolt holes. I used a rubber hammer to check it. I've had some suggestions that would just suggest repair instead of replacement. I hope that is possible but I want to be sure.
