Hey all,
Just wanted some info on this. I have a 25hp with points, condensers, coils type ignition. There is no alternator and the motor is electric start.
1.) Is the term 'magneto' just a word to describe points,condensers,coils type ignition or is magneto a separate part altogether that goes along with this? If it is separate, do all motors have them?
2.) How does this motor generate its 12 volt power to energize the coils?
3.) Can this motor even be run without a battery hooked up and using the pull start?
4.) Will it generate enough power to charge my cranking battery?
5.) Can one load accessories on and still expect the motor to keep the battery charged (radio, lights, etc.)?
I am asking these questions as I am going to buy a designated cranking battery for this motor and considering weight and cost, wonder if I can get away with a small cranking battery that can be kept charged by the motor, or do I need something that will supply all power for the duration of any outing I may take.
Thanks,
~JC
Thanks,
~JC
