Re: How do I DVA test stator non-starting motor
Hahaha ... your right jeffersondodson. I had posted earlier and forgot to mention it in this one. Its a 1984 Mariner 90hp Inline 6. I talked to the a fine tech at CDI and in as much as I was using other mentioned methods of measuring the stator he said the best way was to disconnect all stator wires BUT engine ground and take measurements from the stator wires Blue to Gnd, Blue/White to Gnd, Red to Gnd and Red/White to Gnd. The measurements should be along the lines of this +/- 20 to 30%:
Blue 5000Ω - 7000Ω Mine read 5300Ω
Blue/White 5000Ω - 7000Ω Mine read BAD 2570.0K OHMS (thats in the Mega Ohm range)
Red 200Ω Mine read 148Ω
Red/White 200Ω Mine read 148Ω
Funny thing, if I moved the flywheel a little, the meter changed a lot for the bad Blue/White wire and the other Blue wire stayed close to the original reading.
My stator appears to be the original one based on wire type, thickness, fading and cracking.
The tech also told me some good info. He said that the Mercury factory recommended replacing the Switch Boxes every 7 years and if both were 10+ years old to replace both at the same time. He also told me to check the individual coils by removing them, carefully pealing back the black protective rubber case and look for cracks on the ferrite core. Boy was I surprised when I saw that three of them had hair line cracks which defeated the idea of what the core does. I will post some of this info in a separate post for others searching for this type of info. I forgot to mention he said to measure the coils secondary to the engine ground for a +/- 1kΩ. I didn't get that far since I feel that 4 out of 6 are bad. Looks like all need replacing plus the stator.
