Re: Chrysler specifications
Well, since you seem to have trouble believing me, here are some photos. They are a little out of order but the small block has the angled plugs and the starter motor would be on the starboard side. The manifold is relatively flat and it uses a smaller carb -- I think 1 3/16 venturi.
The black engine is a Force 50 with the same head configuration as Chrysler.
The big block is the engine lying on the floor. Note the straight plugs and the higher manifold. It uses a 1 5/16 venturi carb. The starter motor mount is on the port side of the engine.
Now, mind you: chrysler made these engines for a number of years and may have made different configurations--perhaps for export trade. I haven't seen them all and probably won't in my lifetime.
The question in my mind though is: If you appear to know the answers, why are you asking the questions?
