Guy running his 7.4 454 at 3800 RPMs on muffs. Can't be good.
Friscoboater
Fast forward to 4:31. This guy puts it in gear and revs the engine to 3800 RPM and leaves it there. Then gets out of the boat to show you the prop.
RIDEPATE
Re: Guy running his 7.4 454 at 3800 RPMs on muffs. Can't be good.
Wow, Under no-load = Moron.................9k, Nah I'll pass..........
superpop
Master Chief Petty Officer
You can't fix stupid.
DuckHunterJon
"Gonna let her breath a bit"??? I think he's been breathing something a bit too much!
RogersJetboat454
Let's see..... Spinning prop, potentially wet fiberglass on the stern, and the guys climbing all over it with one hand on a video camera. Sounds like a brilliant chap to me!!:facepalm:
mlrman
man that just can't be good, with no resistance or load against the motor.
jopes
I have never touched a bravo drive, but shouldn't he have had muffs on the lower unit and not just hooked up inside like he did?
cr2k
Being that carefree in the driveway makes you wonder how he is on the lake.
ufm82
Nope-a Bravo's raw water pump is on the engine- nothing in the L/U.
Friscoboater
I was blown away when I saw this.
NYBo
Having no load shouldn't matter if the revs are kept down. The problems with running with no load are the great potential for over-revving, and the lack of cooling water on the leg especially in the propshaft area (not sure I stated that clearly :redface:).
veritas honus
This is the BIGGEST issue...:eek:
jigngrub
Unless it goes BOOM or CRUNCH it's all good eh!;)
... and even if it does go BOOM or CRUNCH he'll have learned a valuable lesson and it won't be any skin off of our noses eh!?
... and there'll be one less "waker" on the water to disturb our fishin' while he's getting it fixed!!!:D
fishrdan
That's no test to see how well the boat runs!
A messily 3800RPM :rolleyes: wimp... Swing that puppy out to 6K and let it sing :eek: When something goes bang, clunk, crunch, you have found your problem :D
Friscoboater
I am glad I was not the only one that thought this was crazy! Did anyone read to the one comment on the Video page? Pretty funny.
Donzi GT250
Good thing the kitty was sleepin
